CASPIAN RDC Monitor BETA version 1.1 RELEASED
Posted: Sat Sep 12, 2026 10:45 am
We are releasing the next BETA version, 1.1 Build 7.14.0
This version has many updates including dynamically identifying connected generator model, serial number and the PIN. This BETA version will work with ALL Kohler generators using an RDC 2.5 RDC controller
Several logging options including real time event viewer. Retention of some values between generator runs.
Two views, BASIC and DETAIL provide all the data you need and information Kohler does not provide in the APP including the PIN for your generator.
We have parsed the entire firmware BIN file and we will be adding more features for the next release BETA 2.0 None of the releases contain any "Call Home" instructions, your data is safe.
Post here if you would like a copy of this beta release This is not public domain software, the source code will not be released. BETA Testers who provide what we need will receive a free copy of this program when 1.0 is released.
This is a the monitor attached to a 38RCLC liquid cooled generator with coolant temp and oil transducers, it is a bench unit, not connected to a generator, thus no readings are available but it still creates logs and connects to Kohler's OnCue server
